Troubleshooting code
Old May 25, 2006 | 04:31 PM
93b20z's Avatar
Default Troubleshooting code
i had a code that read out 24 on my 94 ls ecu... i figured it might be my tps sensor... what could it be... is it tps or is it another???
any comment that will be helpful will be greatful
Old May 25, 2006 | 09:10 PM
Simple's Avatar
Default Re: Troubleshooting code (hmongyaj7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow</TD></TR></TABLE>
i dont see a code 24... re-check it.
Old May 25, 2006 | 09:54 PM
Frozen E's Avatar
H-T White Ops
You sure you're not getting two seperate codes? A 20 and a 4 perhaps? Makes sense if you look at list supplied above.
Old May 28, 2006 | 11:11 AM
93b20z's Avatar
ill go check and get back to you guys
Old May 28, 2006 | 10:49 PM
93b20z's Avatar
well i checked it again and its reading
10 IAT - intake air temperature sensor. how do i fix that??
94sib20
Old May 28, 2006 | 11:04 PM
Frozen E's Avatar
H-T White Ops
Just going out on a limb here, but try to replace the IAT?
Old May 29, 2006 | 02:21 AM
JDMlyfestyle's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">Just going out on a limb here, but try to replace the IAT? </TD></TR></TABLE>
Or plug it in..lol
Old May 7, 2009 | 08:37 AM
stephensmargaret's Avatar
New User
Codes I need fixin!sorry I got to try to post cuz I can't post till 15 days and i need help NOW DAMN IT!CODE 4,7,9,14,4 and 9 deals with sensors on the distributor,7 and 14 on the throttle f'ing body,I got a little jdm d15b,I changed the exhaust manifold to a z6,any advise?I don't want to give my hard earned money to some shop when I can fix it myself,Get a new distributor?new wire harness?SHARE YOUR THREAD DAMNIT!eg6
Old May 18, 2009 | 04:59 PM
2000hondacivicex's Avatar
New User
My 2000 honda civic is throwing a code, and it says that its missfiring on 1,2,3,4 but it seems to be running fine, what should i do??
DA_Boy_626
Oct 3, 2007 06:50 PM
CustomX113
11
Sep 1, 2006 01:27 PM
Phrost
May 29, 2006 02:44 PM
kantfadedisazn
38
Feb 13, 2006 10:07 AM
xxthabest1xx
Mar 15, 2003 06:06 PM
