Bad Tranny Bearings??
1 Post
Is there any way to tell if a bearing is bad..?? Just by taking it out an spinning it should I be able to tell..?? I just bought 95 SI tranny and it's making whining noises when I downshift and when at idle, clutch pressed in noise goes away... Think maybe I was sold a jacked up throwout bearing, even though its brand new could this still be the culprit..?? Would a pilot bearing make this whining noise..?? Mainly im j/w is can u tell if a bearing is bad just by spinning it an stuff..??
Re: Bad Tranny Bearings?? (JDM_SOHC)
You should be able to tell by spinning the bearing. if you feel any roughness or here noise in the bearing, its bad.
You also may have gotton a bad input shaft bearing. Thats what happened with mine.
vg7z
14
07-23-2005 06:33 AM
lowbudget88si
03-11-2005 07:16 PM
