Wiring nightmare!
Wiring nightmare!
i just picked up this 1994 cx from a buddy of mine for the low low, but it has wiring issues out the ***, for one it has a FORD yes I did say FORD security system on it and when i disconnect the box from the harnesses it kills power to my starter.Then when you have the lights off at night and hit the brakes the cluster flashes the tag lights and the climate control its irritating anyone that might know what my problem maybe please put in your 2 cents thanks
Re: Wiring nightmare!
The Ford security system have a starter kill on it. So when you disconnect the brain your starter is not connected. Two option either you just pull the fuse for the alarm or reconnect you starter wire. As for the like situation it might be one of your bulb. For your parking/brake bulb require a two prone bulb, but if you put in a one prone bulb it would cause your parking light to come on when you step on the brake.
96Civic_Coupe
25
04-12-2006 01:06 PM
