Eg rear disk conversion ?
I am trying to figure out if these rear brakes came from a integra
this a pic of the rear disk conversion i am trying to figure what car they came from
do all integras come with a rear sway bar?
because the rear lca's doesnt have the hole for the sway bar
or is there a stamp somewhere on the trailing arm to id the part and to know
what car it came from . he said it has abs lines on it
rotor size 9.4
rotor size 9.4
Re: Eg rear disk conversion ?
for the 4 lug rear rotors i know its cheaper to just buy used trailing arms but how bout if one wanted 5 lugs all the way around would one beable to press wheel bearings and hubs in to the existing spindles or are the spindles and trailing arms different?
i looked on an acura parts site and the bearings are the same so the hubs should be interchangable
from what ive seen you can convert to 5 lug by just changing hubs and rotors. the ITR caliper bolts right on with no mods
