identifying si tranny or z6 tranny
Re: identifying si tranny or z6 tranny
i just want the shortest gear ratio tranny available for sohc but not a jdm tranny
so z6 is the easiest to get
Cool Cool Island Breezes. BOY-EE
The 92-95 Si came with a Z6...
Any 92-00 D series trans will bolt onto and work with any 92-00 D series engine.
ANY.
The only difference between the 92-95 EX and Si trans (both come with z6es) is that the EX has a slightly higher 5th gear.
The shortest gear D series trans is pairing up the internals from a D16 DOHC from a 1st gen integra to the internals from a 92-95 Si, IIRC.
ANY.
Seagull Management
Check the stamp in the transmission case. A000 Designates a small bearing case (CX/DX/LX/VX) and B000 designates a big bearing case (EX/Si/JDM D15B Vtec) The only caveat is that I believe the HX coupes also used a big bearing case. Below are pics of the identifying stamps.
A000 Small bearing case.
B000 Big bearing case.
thanks guys for the info much appreciated
any info on your previous d series tranny/clutch/lightweight flywheel setups would be great the best performer for you set up
like i want to get the most power to the ground out of my single cam, with header full exhust bigger t/b cai and stock p28
i just want a fun d till i go B20vtec fully built
no_one_
11-10-2004 06:17 AM
