my brakes locked up
my brakes locked up
i recently replaced my entire brake system. Integ 4 wheel disks with new pads/rotors/lines and reman calipers/booster/master cyl. prop valve. first two days of driving very easy on brakes mostly engine braking. then on third day went to get on freeway and the car slowed alot when i went to shift. brake pedal was hard and couldnt push it in. car wouldnt go faster then 40. i smelt brakes burning so i pulled over and the pads were smoking and rotors were discolored. basically my brakes locked up and it looks like my rotors are done. does anyone have any ideas what could have caused this? has this happened to anyone or a friend? any suggestions would be helpful
Re: my brakes locked up
yeah ive had the same thing happened to me, after like tens mins or so they were good anyway, im not sure what happened. Your saying everything is new? thats werid? what brand of calipers did you buy factory?
im thinking it must be a defective booster because how unlucky could i be to have two calipers stick at the same time
the other day when i got my car towed it moved pretty easily...im gonna remove the lines and flush them and also try to clear the calipers hopefully that does it
