will this short shifter fit?
ok i will be ordering a fidanza short shifter. my car is a 93 civic hatchback with a b16a3 swap. i was wondering if this one would be ok since i have a b16a3 swap and was concern since the shifter and shift linkage may be a lil different. it states that it will fit 88-2000 civics.
here is the link to the short shifter i want to order.
http://www.autoaccessoriesgarage.com...ID=1003&vlink=
Re: will this short shifter fit?
Any d series shifter will fit and so will the b16 shifters. integra (b18) shifters will not fit unless you modify the shift linkage. (they tend to be about half an inch wider and will not fit in the fork of the shift linkage)
ok so im confused now one person said any d series shifter will fit or a b16 shifter. i just want to confirm is that true?
Depending on the shift linkage you have put in. If you have a B16 Shift linkage ANY D SERIES or B16 shifter will fit. Integra (b17/18) shifters WILL NOT FIT. Doesnt matter even if theyre B series. They will only fit if you have a B18 Shift linkage. The only way to get the b18 integra shifters to fit is to grind them down about 1/2 and inch. the b16 shifters will fit in the b18 linkages with spacers to fill in the gap. the fork size is narrower on b16 shift linkages. look up the differences if you dont take my word for it.
THEDirtyDseriesWOOT
04-26-2007 08:56 PM
ichibano
04-05-2003 04:31 PM
