automatic ls into a auto eg.
my friend has a 92 civic auto and he has a auto 95 ls swap into the car..car runs and drives but does not shift on its own ,,he has to shift manually in order for the car to change gears..any i dea on why its not changing gears on its own??are we missing anything?any help will be nice..thanx
Re: automatic ls into a auto eg.
i think that i need a tcm,where is it located on a integra and can i use a tcm from another car as long as its obd1 and how do i wire it up step by step,,
If you have to ask where the TCM is in an Integra, you probably don't want to attempt to do this yourself; it's fairly complex. Go to boomslang.com and they can fix you up with a plug and play harness that uses the Teg TCM to run the trans.
were is it located,i still want to kno,,is it by the ecu or on the drivers side??and can i still wire it in???
his car is not obd2..his car is obd1 so that wont plug in..so i can basically get a tcm and plug and wire it into the ecu harness..what wire goes to what??thats all i want to kno
Seagull Management
Theres somewhere in the neighborhood of around 40 wires to run for a teg automatic TCM, some of them run to the ECU, some to the transmission and some to other places. Its a lot easier to just swap to a 5 speed if you can't get a premade harness. If you do want to wire it up yourself pick up an Integra factory service manual and start checking out wiring diagrams.
D3U1LT
12
11-25-2006 03:49 PM
KiNG $h!t
08-28-2003 09:29 PM
