strut bar installation
Re: strut bar installation (ziich)
Just bought an OEM Si strut bar for my 98 coupe. It looks like I'm gonna have to drill. Anyone know what size bolts/washers I should use?
In fact, if it's the OEM Si bar, it just directly bolts on to the shock tower. Just unbolt the 2 nuts on top of each shock, plop the bat on and rebolt (making sure you don't over or under torque the nuts.
Re: strut bar installation (spoon-ej1)
Yes, you will have to drill. I did the same on my car. I will get back to you on the hardware. I think it is M12. I used Honda bolts and nuts. Use as big a washer as you can on the underside. The Si has a reinforcement plate under there.
Re: strut bar installation (OE Tuner)
The Si strut bar mounts onto the chassis. I dont think 96-98's had the predrilled holes.
thanks, i'll be waiting for your response with the hardware.
Sorry again.
Bolts sizes are not important...just make sure it fits through the hole in the strut bar and get a matching bolt and a washer to hold it down.
My bad guys, I assumed the shock towers of the EM1 Si and the 98 EX Coupe would be the same. I know it is for all EG / EJ1 JDM or USDM.
Sorry again.
Sorry again.
Steve
Re: strut bar installation (CivicSedan)
I don't like those bars cause then I have to drill, which means it is not OEM strength
Steve
