Question: If AC is removed, do you retain heat?
i ask because i am thinking of keeping the AC off when i swap this winter. i know the heater core runs off the radiator, but does the lack of ac effect anything having to do with heat? thanx.
Re: Question: If AC is removed, do you retain heat? (97civhatch)
no, you'll still have heat. there is a heater hose that runs to the heater core. the a/c and heat have nothing to do with each other.
New User
AC is a totally different system i thought, besides having an evaporator block some air to engine, its just dead wieght a little more tension on the engine due to compressor belt freely rotating i think.
Re: Question: If AC is removed, do you retain heat? (TREVER)
Heater will work fine, however, your ability to defrost your windows will suffer, so when it rains, it will become difficult to see.
Re: Question: If AC is removed, do you retain heat? (2camsaam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2camsaam »</TD></TR><TR><TD CLASS="quote">Heater will work fine, however, your ability to defrost your windows will suffer, so when it rains, it will become difficult to see. </TD></TR></TABLE>
You'll keep your heat, and for the fog problem, I found the anti-fog solution from Rain X seems to work well.
Re: Question: If AC is removed, do you retain heat? (Noe Kozz)
sweet, so leave the evaporator and use some rain-x anti-fog stuff and im set? thanx guys, any more tips?
Just take it all out and use the anti-fog. Thats what I did. You should not have that much of a problem being in AZ. Only thing you have there is rain and the anti-fog works fine for me in the rain.
I figure if you gut the car might as well go all out. So that is what I did, BUT its not for everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noe Kozz »</TD></TR><TR><TD CLASS="quote">
You'll keep your heat, and for the fog problem, I found the anti-fog solution from Rain X seems to work well. </TD></TR></TABLE>
the rain x works pretty good too
pliskin679
08-11-2010 01:25 AM
EK k kay
09-23-2005 03:46 PM
