oem fog question
oem fog question
i just bought some OEM foglights from somone here local. i got everything including the oem switch. now on the harness it has the plugs for each fog and a ground for each one as well. then theres a blue wire that is supposed to go to the switch but it doesnt have the plug connected.
How do i connect the lights to the switch? do i have to go and buy the plug separate or is there a way without it? Also, where does the battery get connected?
n e help would be appreciated.
its pretty vague the way you described it but...i think you might need a female connector to connect the "blue" wire to the switch, and the power wire should be connected to the battery or a some wire with a 12 volt source
Re: (frosteg6)
ok the blue wire has no connector to it at all. what do i do? also, where should the power cable be ran from since there isnt one on the harness?
Re: (frosteg6)
i just noticed that on the switch there are 2 holes with something that look like those little silver batteries for watches an stuff. are these used for anything?
alacard
22
01-08-2008 06:28 PM
EJ8chu
Lighting
11-30-2007 12:51 PM
spencedogg
10
05-01-2003 04:03 PM
