RS front Brake Caliper and rotor info needed
Well i have been searching for an hour now and since H-T don't support two letter searches. i was out of luck.
Well here is my question...
Are the calipers in the 95 teg RS any better than the DX calipers?
If so do i just need to buy a bracket and caliper and bolt it on? or do i need the spindle too?
RS front brakes
DX front Brakes
RS front brakes
DX front Brakes
Re: RS front Brake Caliper and rotor info needed (ace1875)
well if found out that the RS rotor is bigger then the DX's and is the same size as SI's.
All i need to find out is if the rotor and caliper will just bolt up or not on the stock DX hub/spindle
Re: (locass316)
RS front calipers are slightly bigger than the civic ex/si calipers. They use the same mounting holes but the RS have a bigger piston i think. You will need either civic ex/si front spindles or some from any integra.
you need either civic spindles with ABS or DC2 spindles , everything bolts up fine.
10.3" brakes are nicey.
Redline96LX
37
02-20-2012 02:53 PM
Mr_Bojangles
05-18-2004 03:27 PM
cnydelSolHybrid
02-16-2004 07:30 PM
