1 piece header?
1 piece header?
Everyone is tellin me that one piece header is really annoying to put on, is this true? Im lookin at a greddy one, what are some other good brands, and should i just pay the extra to get a 2 piece?
Re: 1 piece header? (teknik_civic)
If j00 get a one piece header, chances are good the weight will be very minimal, meaning mounting it from underneath will essentially easier, just a matter of angles...But that`s just my opinion..
Re: 1 piece header? (Sin 2)
depends on the car your putting it in. I had a 1pc light speed header in my old CRX that you had to finesse to get it in. My DC 4-1 pc installs into my Del Sol like cake.
what car is it going in?
It really does depend on the car. For example a one piece header is little more of a hassle to install on a B16 in a CRX, but very easy to put on a 93 CX w/a B16, because of the amount of room.
Re: 1 piece header? (rodrez)
I say get the 2 peice just incase you have to pull your oil pan if for no other reason. Having to pull off your header to get the oil pan off would suck!!
Re: 1 piece header? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I say get the 2 peice just incase you have to pull your oil pan if for no other reason. Having to pull off your header to get the oil pan off would suck!!</TD></TR></TABLE>
Pulling off your header is a ridiculously easy task... 9 12mm's and 2 14mm bolts w/12mm nuts???? maybe I'm wrong... but isn't a 1pc a superior design? (ex: itr stock exhaust mani)
Re: 1 piece header? (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">
Pulling off your header is a ridiculously easy task... 9 12mm's and 2 14mm bolts w/12mm nuts???? maybe I'm wrong... but isn't a 1pc a superior design? (ex: itr stock exhaust mani)</TD></TR></TABLE>
I don't know..but I had the DC 4-2-1 ceramic coated header and loved it!
Guest
Posts: n/a
how sad
you have to be under the car with EITHER header. how are you going to connect it to the exhuast if you aren't? you're not
a 4-1 is better....it's lighter. it also doesn't have to worry about the area where the two sections would be bolted together. That can casue turbulance or a restriction.
ohh, and DC headers are cheap **** that really don't make much power, other than the 2.5" collector one. and if 2 piece was better...then the big companies like headertech, an-r, dtr, etc... would use a 2 piece instead of the 1 piece that all go with
Re: (Caveman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 »</TD></TR><TR><TD CLASS="quote">You can get a one piece, But it is a pain in the *** to put in. You will have to go from underneith the car. Two piece is much easier.</TD></TR></TABLE>
Hahaha, maybe for the mechanically challenged.
I got my 1 piece DC header on my 93 Civic from the top. 1 little scratch that wasn't even noticeable.
Re: (D16Z6racing)
I have an Apex'i GT Spec 1 piece header, and it wasn't hard at all to put in...but it helped that I work at an Xpress Lube and I didn't have to jack the car up to put it in...
Lucky-13
02-12-2007 10:21 AM
crxtreme89h
23
08-14-2005 01:17 PM
ScottEK
10-20-2002 08:35 PM
