new clutch? newb question
Hey guys and gals, I had a problem the other night... When I was driving home, I noticed that at times when i went into first gear, it would grind a bit, not the kind of grinding when your not fully in gear, not as loud atleast. going into 2nd gear was fine, when i went into 3rd gear, it felt like it wasnt fully in the gear and could be easily taken out of gear w/o stepping on the clutch....going into 4th was good, but again could take it out of gear easily w/o stepping on the clutch....what does this mean? one of my friends told me it may be my pressure plate?
thanks
thanks
i have the same probelm with my hatch, but its with second, and i can shift from 2nd to 3rd then to 4th without steppign on the clutch and i had a new clutch and pressure plate put in about a month and a half ago, so i dont think its the pressure plate. could be synchros, or just a bad clutch,
Re: (BadAzzHAtch)
are you asking if you might need a new clutch? try this. when your in 4th or 5th gear and you floor it..and if the rpms goes up but your car doesnt accelerate..then thats a good sign that you need a new clutch.
Re: (WongFeihung)
i was wondering if I would need a new clutch kit. more about the problem, when i keep it in 3rd and drive, it grinds sometimes and gets out of gear.....also when i started my car tonight...i heard an odd sound coming from the hood....it sounded similar to a t.o bearing out, but not as loud or frequent sound....
accordisslow
01-25-2006 01:24 PM
