Can i use a jdm automatic P30 ECM in my 92 si 5 speed B16????Help
Hello
I have a 92 si hatch. 5 speed , I have a B16A OBD1 Eng. And the only ecu i have is a jdm P30 thats for a Automatic trans. Will that ecu work just fine with my 5 speed car?? Please help ASAP! Thanks To all
It'll work, but throw a code, lemme see if I can find a solution.
http://www.pgmfi.org is down, but they usually have a jdm ecu auto to manual in their wiki,
Re: Can i use a jdm automatic P30 ECM in my 92 si 5 speed B16????Help (nolimitlowrider)
Thanks let me know if you find out any info on that.
Re: Can i use a jdm automatic P30 ECM in my 92 si 5 speed B16????Help (BlueIntegraBoy)
Hi
Have one more Q... On the JDM B16 it does not have a map sensor on the TB, Do you know if the JDM's have one on the firewall or do they not have one at all? Thanks
My MAP sensor is on the firewall. JDM SiR-2 B16A
I used a auto p30 for a year with no codes of any kind. The rev is limited similar to a p28 & 7200-ish rpm. You can tell that the fuel settings are not correct but if you do not push it too hard, you should be cool.
Been using a USDM manual p30 for a while now. It made a noticable difference in the way my engine runs. Much smoother.
My jdm auto p30 will be on its way to Phearable.net soon for manual conversion and chipping.
Re: Can i use a jdm automatic P30 ECM in my 92 si 5 speed B16????Help (EG6_GUY)
Thanks for that info. I may just buy an usa P30 Cause i like for it to run smooth. On the map sensor that goes on the firewall what sensor should i get from what car? Will any firewall map sensor work? i found one from a D15 civic will that one work? CAn you get me the #'s off of your sensor? Thanks again for your help.
The reason I bought a USDM P30 was because I live in a state that requires it to pass inspection/smog. If your state does not have smog requirements, you could find a manual JDM P30 for a good amount less, or pay someone like Phearable.net to convert your auto P30 into a manual P30 w/ the correct fuel map. I believe it costs around $100.
Best of luck to you!
http://www.phearable.net/
Here is what mine says exactly:
Sensor Assy, MAP
DENSO
TN079800-3280
5v PS-30
Hopefully that helps you.
Sensor Assy, MAP
DENSO
TN079800-3280
5v PS-30
nycpatron
02-15-2014 11:23 AM
AustinEF89
02-21-2011 09:51 PM
