Car produce rotten eggs smell!! And bogg'n on 2nd GEAR!
okay, here is the scenario. I started my car up. Rev it to 6-7k rpm while in NEUTRAL. The temp is right where the H letter is. Threw it in 1st gear gun it! Vtec engaged fine. Threw it in second gear and felt a lag. Like my car is trying to pull but not having the strength to. after about 5.5 to 5.9 my vtec comes in and its all good again. But before vtec kick in second gear it boggle. AFter that I put my car to a stop with the engine still run'n and smell a rotten smell. Like rotten eggs or some crazy **** like that! The only thing I did to it before i gun it is add some COOLANT into my coolant. Can someone please explain to me what's going on? Has this happen to anyone else? ThankS!
:EDIT: Oh while I was rev'n the car on neutral I notice some liquid was squirting out my exhaust! What the hell can that be?
Set up:
JDM B16A (first gen)
EM1
Intake.
2.5 pipe'n.
Everything else bone stock.
Set up:
EM1
Intake.
2.5 pipe'n.
grammer nawzi
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote"> I started my car up. Rev it to 6-7k rpm while in NEUTRAL. The temp is right where the H letter is. Like rotten eggs or some crazy **** like that! The only thing I did to it before i gun it is add some COOLANT into my coolant. .</TD></TR></TABLE>
Learn some english, might give you a better response.
Eggs smell can mean that your CAT is burnt up, one of a few things. A clogged CAT will also make your car run like ****, like it's bogging (not "boggling).
Furthermore, why the expletive are you taking your temp all the up to where the H is then slamming it into first?
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (sicky)
yep, sounds like your cat is dead, time for a new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote">okay, here is the scenario. I started my car up. Rev it to 6-7k rpm while in NEUTRAL. The temp is right where the H letter is. Threw it in 1st gear gun it! </TD></TR></TABLE>
I lol'ed at that.
I lol'ed at that.
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">yep, sounds like your cat is dead, time for a new one.
dude, that sounds like a description of someone trying to break something. im w/ everyone else though, sounds (i guess couldnt comprehend alot of it) like a cat.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">
Furthermore, why the expletive are you taking your temp all the up to where the H is then slamming it into first? </TD></TR></TABLE>
Okay, smart guy. I was trying to make it short so people won't get bored reading alot of nonsense. Anyways, it has nothing to do with the cat at all. I found the problem and resolved the issue. Thank you for all your replies though. At least you guy attempted to help.
Re: (tatmark1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 »</TD></TR><TR><TD CLASS="quote">egg smell means ur running lean i think
water from the exhaust </TD></TR></TABLE>
You're close.
You're close.
I thought rotten eggs means rich. and it means the cat is working very hard because its rich...
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">well, its hard to diagnose a poorly described problem.</TD></TR></TABLE>
don't get butt hurt
don't get butt hurt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro »</TD></TR><TR><TD CLASS="quote">I thought rotten eggs means rich. and it means the cat is working very hard because its rich...</TD></TR></TABLE>
Yes, rich conditions kill the CAT you need to fix your catalytic converter.
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (civic_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatch »</TD></TR><TR><TD CLASS="quote">Yes, rich conditions kill the CAT you need to fix your catalytic converter.</TD></TR></TABLE>
fixing the cat will result in another dead cat.
fix the problem, THEN fix the cat.
Re: (LHD 95 EJ1 - RHD 93 VTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LHD 95 EJ1 - RHD 93 VTI »</TD></TR><TR><TD CLASS="quote">maybe it smells bad cause he has an actual dead cat (meow) stuck in his motor somewhere haha</TD></TR></TABLE>
haha
haha
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (rlockwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rlockwood »</TD></TR><TR><TD CLASS="quote">
fix the problem, THEN fix the cat.</TD></TR></TABLE>
fixed everything already. get off the topic.
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (agreer97)
yes please enlighten us to how you solved the problem so when the next person comes by that tries to explain something very poorly we can quickly tell him what to do
Re: Car produce rotten eggs smell!! And bogg'n on 2nd GEAR! (Soccerking3000)
actually, it was something so stupid i'm too embarrassed to tell you guy
comedian?
comedian?
Re: (sicky)
ITS A DAMN HEADGASKET..... read his post.. hes losing water... his ******* temp guage is at the H level wich means shut the ******* car off.. not slam it in first.. the rotten egg smell is coolant burning..
Re: (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic »</TD></TR><TR><TD CLASS="quote">ITS A DAMN HEADGASKET..... read his post.. hes losing water... his ******* temp guage is at the H level wich means shut the ******* car off.. not slam it in first.. the rotten egg smell is coolant burning.. </TD></TR></TABLE>
I doubt that he'd be imbarrased about that.
Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">
I doubt that he'd be imbarrased about that.</TD></TR></TABLE>
But maybe he would be if he ran the rad dry.
Is that what it was? Just tell us already.
