having trouble wiring up my raybrig fogs in my ek
harness is all done i have a red wire which is think is for power where do i wire that tooo thanks for the help
Re: having trouble wiring up my raybrig fogs in my ek (lsvtecej6)
The connector should have a number on it (if this wire does go to the fuse box). Please provide pic and give a little better description of the wire. Is it on the engine bay harness or switch harness.
i dont have pics but i had to cut the brown connectors from the light hrness and the switch harness and wire them together cause i have a ej6 with ek front and the switch is in and wire just no power and not sure were i wire that last power wire
anyone no of were i can find a write up on hoe to wire that power wire into my fuse box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecej6 »</TD></TR><TR><TD CLASS="quote">it donr have a connector on it so i have to buy a female im guessing</TD></TR></TABLE>
Yup, buy a female connector. It will fit in the slot. I hope there was a white wire you connected to the fusebox as well.
Re: having trouble wiring up my raybrig fogs in my ek (BlueIntegraBoy)
nah no white wire just the red one switch plug and a brown realy lookin thing
yes and i cut it to connect to the foglight harness i had no factory plug on my harness like my boys ex did
do i have to strip the wire before i put it in the female or does not need to be striped kind of a dumb question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtecej6 »</TD></TR><TR><TD CLASS="quote">ok ur the **** u owna ek i wanna see pics</TD></TR></TABLE>
I don't, but I installed my JDM fogs on my EG.
aight im a give it a shot in the morning if i run into any more trouble i will reopen this thread
still having trouble i only have one wire left it is a red and white wire im nont sure if it goes to the battery or not
i need to figure out were the blue red white wire with brown connector plug goes to in the switch harness
