what Front sway bar to use
Im thinking about getting a front sway bar for my 99 hatch
i just wondering what options are out there
22mm itr sway bar??
26mm sir sway bar??
any help would be great
thanks
22mm itr sway bar??
26mm sir sway bar??
thanks
Batpool
Re: what Front sway bar to use (SpoonKid)
Go here:
http://www.jdmuniverse.com/for...ybars
Read up and decide from there what you want your car to do. Once you get that then you can figure out what bar front and even back to use.
21mm EX bar would be fine. You dont want a huge front bar, because our cars already understeer alot. The rear sway is what helps the most.
Re: what Front sway bar to use (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">21mm EX bar would be fine. You dont want a huge front bar, because our cars already understeer alot. The rear sway is what helps the most.</TD></TR></TABLE>
actualyl its best if you match the front bar to your rear bar and all your other components, im going to run a HUGE front swaybar, because i have koni yellows on max still in front and a smaller bar in the back because its a little less stiff back there
sfr4dr
20
09-28-2002 12:09 PM
