Check Engine Light!!! P0505
I have a b16a2 and my check engine light comes on and my idle jumps to 1500rpm if i give it a little gas, from 1500 to 2000rpm it will boggle but once i pass 2000 its normal. i already changed my MAP sensor but it s giving me error code P0505 IDLE SYSTEM ERROR. any advice would be great. HELP!
Re: Check Engine Light!!! P0505 (jdmkdiddy)
I'm bored so i'll try to help you. If you look at the top you will see this thread
https://honda-tech.com/zerothread/1171263
Which gives you all the codes and what they are.
P0505 Idle Control System Malfunction, I would look at your IAC.
Do a little research using the red search button at the top right corner of your screen https://honda-tech.com/zerosearch. Dont just replace the IAC till you KNOW it is not working. For all you know there could be an open in your circuit and the IAC is just fine.
And welcome to Honda-Tech
DannyITR
07-21-2004 05:10 PM
champwhiteitr
03-17-2004 03:39 PM
