what ecu can i step up 2???
my motor is a d15b7 with a stock p06 ecu... what ecu can i interchange with? what would be the best for this motor if possible? are obd-1 ecu's interchangable? read somewhere the p75 can be used and thats for the interga, so... just want to know. pros n cons.
Re: what ecu can i step up 2??? (underdog_racer)
all obd1 ecus are all compatible. Why would you want a diff ecu? unless you built the sohc.But even then you would have to tune your car. Which means you would have to chip your ecu.
