EG civic EX cluster into DX EG
Old 04-10-2008, 10:20 PM
vspec128's Avatar
Default EG civic EX cluster into DX EG
I m sorry to ask this noob question but if i were to put an EX cluster to replace my DX cluster w/o the rpm guage would i be able to just plug and play for the ex cluster with the rpm guage and the rpm guage would work ? or do i have to do some custom work? any how to's to do this?
Old 04-10-2008, 10:32 PM
Neekstar's Avatar
Default Re: EG civic EX cluster into DX EG (vspec128)
if theyre both from EG then its plug and play
Old 04-11-2008, 01:17 AM
DOHChatchGUY's Avatar
yup. just take the old one out and put the new one in
Old 04-11-2008, 05:48 AM
slo_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vspec128 &raquo;</TD></TR><TR><TD CLASS="quote">I m sorry to ask this noob question but if i were to put an EX cluster to replace my DX cluster w/o the rpm guage would i be able to just plug and play for the ex cluster with the rpm guage and the rpm guage would work ? or do i have to do some custom work? any how to's to do this?</TD></TR></TABLE>
it takes 10 min or less. take the 2 screws out of the plastic cover around the bezel. then pop it out...dont forget to pop out your clock(if you have one) and unplug your hazard button. then move that out of the way. then like 4 screws and pull the cluster and pull the 2 plugs out and your old cluster is out. then do the reverse for installation. it really is simple as pie. good luck.
Old 04-11-2008, 11:32 AM
civic4nick's Avatar
same with the EK? and will this change what your car says its mileage is?
Old 04-11-2008, 11:03 PM
slo_hatch's Avatar
Default Re: (civic4nick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4nick &raquo;</TD></TR><TR><TD CLASS="quote">same with the EK? and will this change what your car says its mileage is?</TD></TR></TABLE>
idk about the installation in an ek...never done it in one. and no..unless your car has a digital odometer, your **** out of luck on mileage...the only drawback of swapping clusters.
Old 04-11-2008, 11:44 PM
DCSportEJ1Civic's Avatar
Default Re: (slo_hatch)
to retain your mileage take the clusters apart and swap your speedo into the new cluster.
Old 04-12-2008, 12:23 PM
StreetRiot_DRE's Avatar
Default Re: EG civic EX cluster into DX EG (slo_hatch)
yup its just plug and play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
it takes 10 min or less. take the 2 screws out of the plastic cover around the bezel. then pop it out...dont forget to pop out your clock(if you have one) and unplug your hazard button. then move that out of the way. then like 4 screws and pull the cluster and pull the 2 plugs out and your old cluster is out. then do the reverse for installation. it really is simple as pie. good luck. </TD></TR></TABLE>
there actually 3 screws holding the Bezal in, lots of people dont realize it and end up breakin the clip where the 3rd srew goes, you have to pop out your hazard lights switch and there is a screw right behind it..[[Screw # 6 in pic]]
Old 06-10-2011, 06:32 PM
killa94's Avatar
I've had a problem in doing the swap and now the speedo reads 20 mph over..Any help in what i can do to fix this.. thnks in advance
Old 06-10-2011, 06:38 PM
virgineg6's Avatar
This thread is over 3 yrs old! Just start your own thread!
hondaracer76544
Honda Civic (2001 - 2005)
11-03-2018 12:08 PM
eG6haTchY
08-12-2008 04:32 PM
korndog
04-23-2008 09:46 AM
redline5th
04-23-2007 07:40 PM
pr_tony_montana
11-10-2004 07:24 AM
Quick Reply: EG civic EX cluster into DX EG
