CEL code number 24????
i have a 96 civic with with obd1 b18b motor. i have the conversion harness so i can use a obd1 ecu. i checked my CEL and its codes 4 and 24. i know that 4 is "crank position sensor" but what is 24??? is that even a code??
Re: CEL code number 24???? (jdmekrobot)
lol i even asked this a few months back. it's not 24, it's 10 and 14 msot likely
make sure you watch the sequence again..
funny.. i was really hoping that someone hasn't bumped my old post lol
Re: CEL code number 24???? (slacks)
hey thanks. where is the intake air temp located on a obd1 motor?
so whats with the crank position sensor cel? how do u fix that?
IAT is on the rear side of the intake manifold (towards the firewall) .. little white sensor i think.. you should also check your idle air control valve which is on the same side and has two hoses connecting the bottom of it.
and the crank position...... i would check your crank position and if it matches your cam at TDC (top dead center) don't know too much about that one lol
sneakernoob
26
05-27-2007 09:19 AM
99bb6
10-06-2004 11:29 AM
