car won't start need help
it was driving fine last night before i parked it..went out today and the car wont start..when i go to start it, it makes a like fast tapping noise. also my 4th fuel injector to the right is leaking gas..any ideas on what's wrong with my Sol?
Re: car won't start need help
tapping from inside the vehicle? this sounds like your main fuel relay clicking. Check your grounds i ran into this same problem before. atleast by what it sounds like?
as soon as i push in the clutch to fire the car up...nothing instead i hear a fast clicking noise inside the car..i opened the hood and i hear it also
could be the battery jump some wires from a different car and see
yeah when i had this problem it was a loose ground wire on the battery. if you check your main grounds i think you will find your problem.
i don't think the batttery would cause the trans to shift badly. if the voltage was too low to make the trans shift worse it would have a hard time running and starting like you have already experienced
but you can check your battery voltage your self with a meter and if you need it load tested take to autozone or advanced the will check for free.
gavingt
06-22-2017 09:28 PM
laziebun
04-24-2008 11:10 AM
