HID question
HID question
i was told by a friend that if I wanted to upgrade my lights to HID's I would have to get different headlight housings because it will melt the plastic. Is this true? I only want to run 8000k kit. please help.
thanks.
thanks.
Re: HID question
Guys! HIDs run cooler then Halogen, so how in the hell is it going to melt the housing if your halogens didnt. Common sense and lots of wrong information going around.
1 Post
Re: HID question
i have HIDs on my OEM CTR headlights. why are people so scared that the bulbs will burn your headlights? idiots! dont listen to people who dont even have them.
Re: HID question
I had projectors in my previous car and on the housing it even said not to install HID KIT. So I did it anyways, and I didn't have any problems. The lense of the headlights weren't NEAR as hot as the halogens.
It's like the "turn off your cell phone" at the gas pump MYTH. Even the retailers believe the crap sometimes.
Re: HID question
No, it won't melt your headlight housings. But you will blind everyone driving in front of you as well as going the opposite way of you with your crappy PnP HID kit. Oh, and you're a ricer.
Do it once, and do it right: get a retrofit or stick to Halogen bulbs.
Re: HID question
so in order not to blind the hell out of incoming traffic, I need to upgrade from stock housings and lenses? sorry, just a little confused after compiling all of the info.
1 Post
Re: HID question
im on "doit once! doit rite idea" but, ive had no issues with my plug and play kit. noones flashed me... i think people on here just want to cry about anything.. ive gotten flashed in my wife's fit when i forget to turn high beams off(with have stock light) but my eg hatch has pnp kit and i havent had one issue....i even pass cops all the time and they are dicks around here and havent had a problem...
Re: HID question
...and here's what it looks like when you're driving:
Finally, what it's supposed to look like:
See the difference? Don't be a ricer, and don't waste your money on rubbish HID kits.
Re: HID question
It is true that HID run cooler than the stock bulbs, even so for our 55w kits.
So why do the ebay lamps melt with HID you ask?
The quality of the optics is so bad, so improperly designed, that the incorrectly focused intensity of the HID ouput melts the front of the lamp or the bezel next to the projector. OEM projector lamps can run HID all day and not do this because there is actual research and development put into those products. That is why a single OE lamp costs twice as much as an ebay pair of projector lamps.
Re: HID question
i bought my kit from VVME.Com on my old car and have had no problems what so ever with it was plug n play with 10000k bulbs
Re: HID question
The CLASSIC
PnP Vs. Retro ****!
Buy what ever makes you happy. And what you can afford. Not many people are capableof opening their headlights up and doing all that work. Plus the gang of $ behind it also.
PnP Vs. Retro ****!
Re: HID question
Re: HID question
Just to add more fuel to the fire, yes, we've seen melting with ebay lamps, we also have many clients running our 55w kits in similar ebay lamps with no problems. It does vary from model to model of lamp. Our recommendation is never to goto the ebay lamps unless you know someone else is running them with actual decent output.... because many go int he opposite direction.
Re: HID question
my output with ebay lights with silverstars sucked, thats why i went hids, but my ebay lights with hids, are 10 times better them my buddy with oems and hids, not saying mine are perfect but he throws out a lot more glare.
also op dont run past 6000k
