B16 map sensor
B16 map sensor
Ok so i was wondering if you can use a d15b7 map sensor on a od1 jdm b16a swap (second gen). Im asking this because the swap did not come with any wiring harness or plug ins for the b16 map (note: the b16's map sits on top of the throttle body, the d's sit mounted on the firewall) So ive been using the d15's map sensor. Also I have a bouncy idle and im think this is the reason, Ive already cleaned the IAC twice so ive ruled that option out. If anyone has any info on this that would be great.
Brian Hinson
13
06-24-2006 04:05 PM
Yellow Dragon
07-23-2003 02:01 PM
