Clicking sound when I open driver's door - what is it?
I hear two clicks when I open the driver's door. They're clicks at certain points where the door is opened - and it's not hitting the fender. I can't see that it's hitting anything really...
Re: Clicking sound when I open driver's door - what is it?
its the hinge. it has 2 different spots on it that hold the door open at 2 different increments.
I'm gonna give that a try. It seems like it's hanging a little bit, but we'll see. Thanks for the advice.
my driver door does that as well, found out one of the bolts that is on the hinges are stripped.
you might wanna check that out
I realized that the pin holding the hinge together is cracked at the top. When the door "clicks" then pin readjusts itself. Any idea where I would find a replacement pin? Is that even what it is called or is it a bolt of some sort?
go to: http://www.hondapartsunlimited.com/ to get the parts diagram up for your civic and you should be able to get a part number for it and pick it up or order it online.
D16Z6racing
06-05-2007 05:32 PM
FR-MOB: ThE bEe GuY
07-14-2003 09:11 AM
