94 Sol Si, SRS Light on all the time!
Sol to Sol
Hi, I bought this car, and have no idea what happend to it. Its not in bad shape, but obviously had damage bad enough to set off the bags. The core support is pushed in about 1/2 in or less, so it wasn't too bad, but still...
I've replaced the air bags, and had Myairbags.com reset the SRS unit. I followed the instructions when I replaced it.
I put it all back together, and yet the light wont go out!!
I tried http://www.myairbags.com/Reset/HondaReset.html this, but the light NEVER goes out!!
Then I looked for the ODB connector, but I didn't think a 94 would have one, so now I'm stuck!
How do I check the sensors, as they are the only things left?
Thanks!
Thanks!
Sol to Sol
Re: 94 Sol Si, SRS Light on all the time!
How about... In case of catastrophe.. That I PROTECT MYSELF and any LOVED ONES, in one of the smallest cars ever built?
Yeah, forget that..
Yeah, forget that..
Sol to Sol
Yeah, it does, and so does the cruise control.
So its not the clock spring, but thanks!
And WELCOME to H-T noob! Hope you like it here
Sol to Sol
Well, myairbags.com says it should work, but it dosen't
How can I test the sensors? I can get to the harness at the SRS unit, anyone know the pins and the resistance to check??
Sol to Sol
If someone could tell me where the sensors are, I'd be grateful.. Or what pin # to check on the harness to see if they are in spec, and what IS spec #s anyway?
Thanks!
Thanks!
I had the same question a while back. Here you go. Hope it helps
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/srs-abs-light-how-remove-2672608/
honestly if the main unit works enough to set off the air bags and you put new airbags in there should be no reason why it shouldn't work.
i would assume it works and take the light out if it's bothering you that much
Sol to Sol
Thanks, itsnotfast!
But I have no idea what the service connector is lol.. Is it above the computer, or the same wire you read check engine codes? I'll look tomorrow under there, but I didn't think that was on the SRS harness.. I've been trying to reset it with the MES connector from http://www.myairbags.com/Reset/HondaReset.html
IF these are the same, thats great, but it dosen't blink or anything EVER when I cross the wires..
And Brute, its controled by a computer, to be sure it dosen't set itself off unintentionally. So, yes I did replace the parts, and it SHOULD work, but I still need to reset the computer to let it know that everything is working. Thats the whole problem i'm having..
It wont blink EVER! lol..
RON where are you?? lol
From what myairbags said, it's in or around the fuse box. In my EK its above the ECU. I don't think you check it from the OBD port.
Sol to Sol
Well, using the exact plug on the link from Myairbags, I get NOTHING, NADA, ZIP! lol
And there is no ODB port so, I dont know.. All it does is look at me like HAL...
I got the SRS unit and harness from the car that had the airbags, so I'm gonna try that tomorrow.
Sol to Sol
well, i put in the SRS unit from a friends car, and guess what??
IT WORKED!!
So now I am talking to Myairbags.com to see what they will do about it.
I either want my money back, or them to fix mine right!!
<-----<<< is NOT a happy camper!
IT WORKED!!
Sol to Sol
Thanks, they claim a 100% guarentee, but who knows.. At least I went thru paypal, so if they give me a problem, PP will step in.
I hope...
I hope...
JarvisW
35
08-22-2009 10:52 PM
