Does a 94 Integra swaybar fit on an EK?
It may be a stupid question but I have heard conflicting opinions. I heard from one source it does but I have one and it doesn't seem like it would fit when I checked. Also, if it doesn't work, what 96-00 Civics came with sway bars that I can use?
Re: Does a 94 Integra swaybar fit on an EK?
well if u have the sway bar try and put it on if it doesnt fit then u answered you're own question. and 2. the si came with sway bar
Shoklid, like I said my first post I did try before and it didn't seem like it did. And xxstuntin4life, How?
it definitely fits, you need the brackets from a EM1 (99-00 si) and endlinks if you don't have that stuff... should be an easy bolt on after that
Would an auto parts store have that stuff or would going to a dealership be better? There aren't many junkyards near me and the only one I know of rarely have cars that new.
Well, I checked the dealer and for all the stuff it is $155.82 but from Adavnced it is $75 not counting the brackets. Un-less those brackets are $80 Advanced is cheaper. Also, for stock endlinks from Advanced it comes to about $80 when after market endlinks from ASR are the same price.
i just sold my integra sway that was on my ek hb for $30 w/ all brackets. so look around. you also need aftermarket lowwer control arms or oem ones with the endlink holes(si, lx ect)
I have some Integra lower control arms but I was told that they are not the correct length, is that true? Also, this is looking like a long and expensive process just for a sway bar. Is it worth it. Also should my stock ones have a hole in the location where one would mount a sway bar endlink.
all 96-00 rear lca's have the holes for a rear sway.. if you run anything more than a 13/14mm i would suggest getting a subframe brace.
here's more information:
http://www.teknotik.com/jdmrides/for...read.php?t=236
if you cant figure out what you need from that, you're hopeless.
yeah even my dx has the sway bar holes... the brackets are about $8 apiece from majestichonda.com and you can get blox endlinks for about $30 I think
Just did it 2days ago on my 96 ek4dr. you need 99-00 si endlinks that I got on ebay for $28 shipped and you need 99-00 civic si bushing brackets, $10 each at the Honda Dealer. you kinda have to squeeze the rubber on the swaybar ends, doesnt fit 100% perfect, but it works..
alwaysoverkill
Suspension & Brakes
02-12-2006 08:14 PM
Amuse9
12-30-2002 12:48 PM
