putting a teg dash in need help?!?!
need diagrams to the civic to re pin the teg plugs to fit in the civic harness, can anyone help out here? if so thanks in advance.
Re: putting a teg dash in need help?!?! (infamousRRH)
Here you go. . . . this is mine. Hope you like it. . . .
If you need any help. . . . . . .just ask.
if so..here it is..
teg's blue left side plug (13 pins)
1.blu-tach signal
2.grn/org-check engine indicator
3.yel/red-oil pressure switch
4.-
5.wht/blu-charge indicator
6.-
7.yel/grn-coolant temp
8.blk-ground
9.red/blu-cruise (if you have cruise)
10.yel-hot
11.-
12.pink-maintenance (not used)
13.-
teg's right side blue plug (16 pins)
1.grn/red-e.brake signal
2.red/grn-high beam
3.grn/yel-right turn
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
9.blu/red-abs (not used)
10.grn-trunk switch
11.org-vehicle speed sensor
12.-
13.blu/wht-low fuel (not used)
14.yel/wht-fuel gauge
15.lt grn/red-door switch (not used)
16.red/blu-seat belt
civic's left side grey plug (12 pins)
1.yel/wht-fuel gauge
2.yel/blu-vehicle speed sensor
4.grn/blu-left turn
5.wht/blu-charge
6.yel/red-oil pressure switch
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
civic's right side grey plug (10 pins)
1.red/grn-high beam indicator
2.grn/red-e brake signal
3.-
4.-
5.grn/org-check engine indicator
6.blk-ground
8.yel-hot
9.grn-trunk switch
10.blu/wht-seat belt
1.blu-tach signal
4.-
6.-
8.blk-ground
10.yel-hot
11.-
13.-
2.red/grn-high beam
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
10.grn-trunk switch
12.-
4.grn/blu-left turn
5.wht/blu-charge
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
3.-
4.-
6.blk-ground
8.yel-hot
9.grn-trunk switch
Re: putting a teg dash in need help?!?! (Malachi)
um........this what i did...use your STOCK wiring harness..i have heard problems with using the integra harness...one doens't plug up..and a bunch of stuff wotn' be working...just cut the wire in the back of the dash and connect it to the integra one..
Re: putting a teg dash in need help?!?! (EG Civic)
ok, i was just going to use the plugs for the gsr cluster..then wire them to the civic ones using the little clips that they have at radio shack. i was just wondering why only 2 of the 3 on the integra cluster are used. are all 96+ honda/acura's using the same shaped plugs in the back? i can find 96+ civic's at the junk yard pretty easy, but integra's are a lot harder.
you are getting it all mixed up...Use the STOCK civic wire harness...cut out the part that connects to the civic cluster...rewire it to a integra cluster... as for the radio and so on it will plug right in..you will have to extend the clock wire...and rewire the hazard button....
Re: putting a teg dash in need help?!?! (FASTEG_SERNC)
why will they not fit? lenth? or the attach plug points don't match up? are you sure?? have you tried to match em up? still tight just asking
if you prefer to solder it...do it..it holds better...use the integra plugs that goes into the cluster...but cut the stock civic plugs that goes into the civic cluster out and rewire it...??? ???
Re: putting a teg dash in need help?!?! (WykidEG)
I must admit the dash looks good but having to cut the door panels to make the doors shut looks way worse than keeping the stock Civic dash. Do you plan to fill in the holes on the door panels and have the reupholstered?
Re: putting a teg dash in need help?!?! (Hybrid Moments)
Ok, I used the tegs harness. Have no probs. And didn't rewire anything. It all plugs in. I don't see why all of you people rewire the thing.
http://www.geocities.com/Area51/Laby...gecluster.html
this is a good detailed idea of it
does anyone have any pics up close towards the front of the dash, or on the sides and what did you cut in the back to make it fit? do you have to use integra dash mounts? thanks
ok so this is the third time i read a wiring diagram for that swap. I have a 92 cx, with a teg cluster. The only thing not working is the gas gauge. From what i've seen, i assume all gas gauges for honda have the yellow/white wires. Am i right?
these are the plugs that I need dagrams for. These are the plugs that are the main ones that run to the fuse box. If anyone has these please post the diagrams. thanks
