Removing EG hb rear seats
Re: Removing EG hb rear seats (RedlineUBRF)
The actual seat has a screw in the back middle and then you can pull the back of the seat upward and there are to clip like things on each side just figure those out and your done. The back has 2 plastic clips on each side next to the plastic knock those off and put the seats to the outside of the car and take off the middle part first just comes from there. Hope you understand that.
Re: Removing EG hb rear seats (WhiteHonda)
find the axle that the rear seat backs pivot on. get some needle nosed pliers. on the side near the quarter panel on each seat, reach down in the corner and pull a black plastic retainer clip straight out with the needle nosed pliers. push that seat towards the middle of the car, and then straight out. same with the other seat. now you just have the seat bottom. there is a 10mm bolt just to the right of the middle of the seat by the seatbelt bolts. unscrew it, tilt the seat up towards the front of the car, and then lift it straight out. btw, the seatbacks are connected to the hatch carpet, so that's gonna come out with the seat backs unless you unhook it all first.
