can i use an ls engine harnes in an eg
what up HT, im not really new, just been lurking around for a while and finally decided to make an account. anyways...
ive got an ls in my eg 4 door. the o2 sensor isnt plugged in because the plug off the harness is over by the distributor and the o2 is down near the cat. im assuming the harness was used off the old d series motor. question is can i use an obd1 harness off an LS and still be able to plug everything up?
Re: can i use an ls engine harnes in an eg
no need to make an extended harness.. i used a stock d series obd 1 vtec harness on my JDM B16 and ran into the same problem your havin so i scooped an o2 wire extender.. there pretty cheap at pwJDM
http://passwordjdm.com/PasswordJDM-O...P1767C360.aspx
theres 2 different lengths so you can get the right one so theres not alot of extra wiring in your bay
gl man
gl man
To Answer the OP question, yes an LS engine harness will plug right into your eg shock tower plugs. You can use an ls engine harness from a manual or automatic(just have 3 plugs not doing anything in the engine bay)I just finished this swap in my eg6.
theres no need to go through the hassle of putting a new harness on the motor when his only problem is the fact that he cant plug the o2 wire into the harness.. hence why i gave him the link for an O2 wire extender...
appelsos
07-21-2011 12:23 AM
hefftone79
08-11-2008 09:01 PM
