IAC-Valve problem, Need help
Old 09-13-2009, 05:08 PM
1baddcivicsi's Avatar
Default IAC-Valve problem, Need help
Just got my car running, but now i have an issue. I have an Edelbrock Intake Manifold, & i found a coolant leak where the IACV meets the In.Manifold. The 2-Bolt holes are stripped-out. Which is also causing a HUGE vacuum-leak also
What should i do?
Use the next size bigger bolts & re-thread the holes?
Old 09-13-2009, 05:10 PM
System Lord's Avatar
Default Re: IAC-Valve problem, Need help
re tap those bolt holes first to see if you can salvage it
MHDesigns's Avatar
Is deleting the IACV an option? I know some people are opposed to this.
Old 09-13-2009, 06:04 PM
SlickEJ8's Avatar
i dont thing you can..... re tap it or use bigger blots
Old 09-13-2009, 06:06 PM
MHDesigns's Avatar
I don't have IACV or FITV... both blocked off.
Old 09-13-2009, 06:07 PM
SlickEJ8's Avatar
i know the fitv you could but i didnt know about the iacv. any idle problems?
Old 09-13-2009, 06:16 PM
MHDesigns's Avatar
No, however I don't run a/c or heat or stereo or anything because mine is raced out. I wouldn't do it if you were running a big stereo or anything that draws excessive power. The IACV just adjusts idle to accomodate(sp?) extra power usage. Otherwise the rpm's would drop a little when using power. The IACV eliminates this.
It may not be an option for you if it's just a grocery getter, but it is possible.
Old 09-13-2009, 06:17 PM
Thanks for the feedback everyone, i will figure something out tomorrow.
But EMS will let me run with no iacv, i might check into that.
Old 09-13-2009, 06:20 PM
MHDesigns's Avatar
Forgive my ignorance... whats EMS?
Old 09-13-2009, 07:40 PM
AEM engine management
Old 09-13-2009, 07:48 PM
munster87's Avatar
Engine management system
Old 09-13-2009, 07:51 PM
MHDesigns's Avatar
lol DUH! whoops. Thanks.
hatch_kidb18b1
08-04-2009 05:27 AM
julianbc2
05-12-2009 01:33 PM
Civicman86
08-04-2007 01:20 PM
redboost10
01-20-2007 02:22 PM
MySelfAffliction
02-15-2005 08:09 PM
Quick Reply: IAC-Valve problem, Need help
