car wnt go no where???
hello, i have a civic stock d15b7 , i just brough the car, and i drove it for like 2 blocks, i heard something pop, then the car wont go anywhere, i can shift it in gears without push in the clutch petal or push it..... i was thinking its probably the throw out bearing, but i took my tranny out tonight, clutch look ok, pressure plate look ok, throw bearing look good too, but i have my clutch kit here soon, im just making sure its not my transmission that is out
so pretty much i can shift in gear with or without clutch petal pushed in, and car wnt go anywhere....
im just hoping its just the clutch or the throw out bearing, any help would be very nice!
thanks in advance!
thanks in advance!
Re: car wnt go no where???
they are good, im pretty sure its the clutch or the throw out bearing, its not moving at all, like its in neutral
ok from reading all the other threads, this kinda remind me, when i took out my axels to remove my motor, the passenger side wasnt all the way in, but driver side was, so could this be the pop noise? but wouldnt the trans at least move the car little with the axel lose?????
ya thats wat i was thinking, the its probably throw out bearing came out of its place, but who knows, ill just install the clutch kit, its excedy oem replacement kit, hope it will solve the problem
It really sounds like an axle popped out of the transmission. There should only be about 1/8" gap between the axle inboard joint and the transmission. Have you looked?
uh yeah if your passenger side axle popped out it would deffientely cause the car to not move, considering that is the drive wheel.
90_EX_Civic
22
12-11-2009 06:51 PM
maxboost94
09-20-2007 07:40 PM
siregcivic
08-07-2005 02:01 AM
