HELP!!!OBD2 to OBD1 conversion
hey guys,
i have a 95 civic with obd2 sohc ZC engine, i boosted the car and i wanna get a p28 ecu and a conversion harness.
problem is, i cant understand the obd2 harness, it looks different.
here some photos of it so please help, i contacted xenocron and he didnt have any solution for it.
Re: HELP!!!OBD2 to OBD1 conversion
i swapped from obd2 to obd1.
but i don't understand your question at all.
just a guess, you need to unplug the ob2ecu, then plug in the conversion harness, then plug in the obd1 ecu.
yes that's what i wanted in the first place, but, this looks different than OBD2a or OBD2b harnesses, i need a pin outs for this harness please
I dont understand your question but it looks like you need an obd1 ecu, then get an obd2-obd1 conversion harness and plug it all in.
Seagull Management
I'm beyond confused, hell i'm way past puzzled. It looks like some sort of OBD2 harness judging from that green connector, but the 2 ECU plugs look like OBD1 plugs, but to further complicate things there are only 2 plugs instead of the normal 3. the 9 after the PC2 generally designates an ECU as being an automatic JDM unit, but i'm absolutely baffled about this.
I've seen this before.
It's a bit rare, but last time I saw this was on a Euro EG civic and see that you're from Jordan makes me think Jordan gets Euro model civics.
I don't have a solution either, unless you can snap some photos of the ecu board (with ecu cover removed). If that ecu uses a 28-pin eprom chip, there may be hope to reprogram your ecu.
As for converting to OBD1 normal 3-plug style, I say hit up Rywire. Ryan may have messed around with these kind of ecu's before and has possibly made a jumper harness converter.
PS: interesting to see that green plug too. Its like an EK style harness on an OBD1 car.
thats not what i want, i could do that long time ago, the HARNESS IS WEIRD, not like any OBD2 harness
sean2000gt
01-24-2009 04:32 PM
