Just changed HEADGASKET, still smoking bad!
so i have a boosted d16z6 and when i first did the swap i didnt notice it smoked really at all but now it smokes (white) alot! i just changed the headgasket and its still the same problem. im going to swap my pcv and see what happens but if that doesnt work then im guessing its the turbo or motor. its a brand new 50trim turbo though. i was just wondering what you guys might think the problem is...
Re: Just changed HEADGASKET, still smoking bad!
did you resurface the head? did you check to make sure the block deck is straight? Did you pressure test the cooling system? Always resurface the head before installing a new headgasket.
If its smoking white then the problems related to low coolant, are there any leaks???
Brambo
07-25-2011 07:14 AM
efking1985
13
03-02-2007 09:22 AM
redzcstandardhatch
08-26-2004 09:32 AM
