96 civc (d16y8) squeaking
Looking for some help?? i got a 96 civic with a d16y8 and am having this horrible squeaking sound coming form around my timing belt and alternator. I know that is not my alternator or my power steering because i have removed the belts and it still does it. I changed my water pump and timing belt pulley thinking that was the problem but still nothing. right after i changed the parts i got it back together and it seamed to be good. i let it sit and get to running temp and no sound. I drove it about 15 mile and turned it of when i come back out i started it up and the squeaking was back. i notice that when i have a load on the motor the squeak goes way. but when i let off form accelerating it comes back. any help would be great thanks!!!
Re: 96 civc (d16y8) squeaking
yeah thought it was water pump but that was not the problem so im out of ideas. have u heard of a oil pump making a squealing sound?
Timing belt tension is too tight so the tensioner is screaming from too much load. loosen up the timing belt a lil bit and it should go away. Seen it happen quite a few times.
CALC!_JUST_du_IT!
06-10-2008 12:55 PM
Andy099
09-19-2005 11:28 AM
