EK swaybar problem!
EK swaybar problem!
I just installed my Skunk2 rear swaybar on my EK and when I drive normally, and go over a bump or dip, theres like sqeaky noises coming from the back. I was wondering if this is normal?
Re: EK swaybar problem! (jimmhatch)
Did you lube up the bushings?
Mine squeaks after a couple months, at that point, I just add more lithium grease to the bushing.
EDIT* when you add lube to the bushings, you must remove the bracket/bushing and lube the INSIDE of the bushings.
