no cold air ....
no cold air ....
my a/c blows air but no cold air is coming out whats wrong?? ( yes i clicked the a/c button)
btw... i have a 2000 civic si if it matters
Re: (1hotcivicSi)
if your not certified you can't have the tools take it to a dealer, maybe you have a leak somwhere buy the kit you put the dye in and then see if you can see anything, if you cna't find it take it to a dealer for a fix or a recharge.
Re: no cold air .... (IDriveAHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDriveAHonda »</TD></TR><TR><TD CLASS="quote">Lucky, we're using the heater here. </TD></TR></TABLE>
I was about to say the same thing. I would just go get it recharged, if I remember correctly its not that expensive to get done and your ac will be ice cold. Usually they stay good for a few years without servicing.
Re: no cold air .... (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg »</TD></TR><TR><TD CLASS="quote">o2 sensor. check it.</TD></TR></TABLE>
WOW! Good thought but come on now.
Re: (1hotcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi »</TD></TR><TR><TD CLASS="quote">well if i cant do it myself how much u think it would be ...... why cant i do it myself/??? </TD></TR></TABLE>
because your not EPA certified and refrigerant is very dangerous also it is illegal to vent it into the atmosphere it is a federal crime. also R-134a isn't expensive BUT you still need the equipment to do it, check to make sure you don't have a leak in the system with the DYE kit put that in the system (it is flouresent) so if you do have a leak you can see it with a black light if you have a leak (have a certifed climate control tech) replace the line and charge the system.
preludesi93-arg
12-29-2006 02:49 PM
