What die size to rethread lowe ball joint?
I need to rethread my lower ball joint nut. Helms says its 12x1.25 but i cant find that size die at any stores. Does anybody know what SAE size will work? or can i use 12x1.5?
thanks.
thanks.
Re: What die size to rethread lowe ball joint? (Dominican_Kid)
If you don't have a press, no worries.. when you are ready to remove the BJoint, you can pound/punch them out if you aren't concerned with damaging the old one. Then go spent 30 bucks on a new one and carefully punch it in.
I've done it this way a few times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dominican_Kid »</TD></TR><TR><TD CLASS="quote">I need to rethread my lower ball joint nut. Helms says its 12x1.25 but i cant find that size die at any stores. Does anybody know what SAE size will work? or can i use 12x1.5?
thanks.
</TD></TR></TABLE> I don't understand... Why would you need a press to put on a new castle nut?? In the case you were putting in a new balljoint, then you would. Maybe i'm misreading(but i re-read it a few times..).
thanks.
Pooping on children
Re: What die size to rethread lowe ball joint? (GARBhatch.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GARBhatch. »</TD></TR><TR><TD CLASS="quote"> I don't understand... Why would you need a press to put on a new castle nut?? In the case you were putting in a new balljoint, then you would. Maybe i'm misreading(but i re-read it a few times..).</TD></TR></TABLE>
Im getting the same vibe
He might need to thread it because he mushroomed it when the hammered it out to get the knuckle freee.
You can find a Die for it at ACE hardware (they tend to carry unsual sizes) and no SAE will not work
Re: What die size to rethread lowe ball joint? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing »</TD></TR><TR><TD CLASS="quote">He might need to thread it because he mushroomed it when the hammered it out to get the knuckle freee.
You can find a Die for it at ACE hardware (they tend to carry unsual sizes) and no SAE will not work</TD></TR></TABLE>
exactly. Im going to try them this weekend.
EnjoyTheRideDC2
Suspension & Brakes
11
12-11-2006 10:11 PM
EnjoyTheRideDC2
11-07-2006 12:09 PM
PINKS
17
04-17-2006 06:55 PM
