Can an EX cluster rev to 8,300?
Risky Business
Re: Can an EX cluster rev to 8,300? (miksew)
yes...you will need an MSD RPM activated switch...and then buy an LED to put in the cluster (sort of like a VTEC light) and connect them
Re: Can an EX cluster rev to 8,300? (BauleyCivic)
sounds like someone is getting a b-series swap in a base model civic. what do b16 ecu's usually rev-limit at? im still running my shitty d16 on mine and just wondered. also what do gsr ecus(obd1) rev-limit at? thanks and sorry for hijacking the thred
Re: Can an EX cluster rev to 8,300? (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic »</TD></TR><TR><TD CLASS="quote">sounds like someone is getting a b-series swap in a base model civic. </TD></TR></TABLE>
Or even better, it could be someone building their D Series to rev to 8300rpm or more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic »</TD></TR><TR><TD CLASS="quote">what do b16 ecu's usually rev-limit at? im still running my shitty d16 on mine and just wondered. also what do gsr ecus(obd1) rev-limit at? thanks and sorry for hijacking the thred</TD></TR></TABLE>
And also, the "shitty" D16 P28 ecu is the most common used, even in B Series swaps. Most people just chip them or get a Hondata. But if you must have the GSR ecu, they rev limit at 8200 rpm I believe.
audio5050
02-14-2007 07:22 PM
PhatBoy5015
30
08-17-2006 11:19 AM
