Searched but no help
93 civic lx d15b7 OBD1
car starts, runs, and drives. On the way home from work today, setting at a stop light and my idle drops to 400-500 and it has a sputter. Sounds to be missing. No check eng light. I checked the plugs wires distr. all fine I am not a honda expert so any help I will take. It is getting fuel and the filter was changed 4 months ago. I have vids but my dumb *** camera won't upload to the comp.
Also how many miles do hondas usually get out of the life of there motor. As you can see by the pic. All orig miles to. Should I start to worry??????????
207514
Modified by 93whtlx at 3:31 PM 1/2/2008
Modified by 93whtlx at 3:32 PM 1/2/2008
207514
well it could be your map sensor, not really sure, what you told us is not enough, if it has that many miles sensors tend to go, i would t worry about your motor, but it does have a lot of miles, i would stay on top a maintenance after you fix this problem to keep it going
Re: (Historyg)
Was a tune-up ever done in the time you've owned the car? I would start there if it hasn't because chances are it needs done regardless. Pull the plugs out and take a picture of what each of them look like. This well help us help you diagnose your car correctly.
