Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable?
Re: Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable? (dpine)
yes, the hatch's b-pipe is longer because the cat is on the exhaust manifold. The coupes the cat is underneath the so the b-pipe is shorter. You can use a coupes b-pipe on a hatch but you have to move the cat underneath the car or get a test pipe.
Re: Are 96-00 civic hatch/ coupe exhaust B-pipes interchangable? (2khb)
Even when you compare the DX coupe (which had the cat in the same spot as the hatches) the B pipe is a different setup completely. the hatch has a shorter wheelbase than the 2/4 doors do. So, in a nutshell, it is not a direct bolt on. You can use a coupe B pipe but you'd have to cut and weld on it to make it fit correctly.
Skeletor
03-31-2005 06:44 PM
