how do i order bearings??
and no it isnt just call and ask for them its confusing involves colors of the old bearings and whatnot just wanted to know becuase i need new oem bearings for my allmotor build but i want itr bearings
Re: how do i order bearings?? (Midori Green)
Order the bearings for your block. Match up the letter and number on the crank and rod and order the color it matches up with on the chart in the service manual. There will also be letters stamped on the block which indicates the block side of the crank bearings.
Re: how do i order bearings?? (EG8R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8R »</TD></TR><TR><TD CLASS="quote">Order the bearings for your block. Match up the letter and number on the crank and rod and order the color it matches up with on the chart in the service manual.</TD></TR></TABLE>
its a swap... so i have no service manual.. and the bearings i need are not the same as the block i am using
Then get a service manual. Or find access to one.
So you are not using an ITR block, are the bearings that much different if at all compared to what came OEM in the block you are using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8R »</TD></TR><TR><TD CLASS="quote">Then get a service manual. Or find access to one.
So you are not using an ITR block, are the bearings that much different if at all compared to what came OEM in the block you are using? </TD></TR></TABLE>
my block is a b20b block (2 layer design) therefore the bearings are not the same as vtec bearings (3 layer design) the size and fitment of all the b series bearings are universal on other b series blocks... you get me??
I was not aware of that.
I know that Honda does not have any information on how thick each bearing is for each color. I've tried looking before. It would be quite expensive to order bearings of the same color and plastigauge them and find out they are not the right size... But that is a way to do it, but again, it might get expensive.
brokenojoke
12-22-2005 09:25 AM
