1st mod
Re: 1st mod (nocaryet)
it would help if you gave more info on engine/vechile/what you want out of the car..basically figure out where you want to go with the car then sit down and see what options you have good luck
Re: 1st mod (XxSOHCDriVerxX)
jdm air freshener
save up for a swap.... dont do the body kit and paint job......
Re: 1st mod (gumbii)
YOU CAN'T lose with suspension. I would def invest in some coilovers if i was you, along with maybe some rotors, and pads. But they're right, it all depends on the car and year. Focus where the car needs the most work first. good luck bro.
Hondata is always a first good mod....forget the cold air intake, or the headers for right now.....just get a hondata first....then you dont gotta worry about it later....
Re: 1st mod (Blck_Hatch_of_Doom)
whoops. forgot. i have a car now . its a 98 civic coupe dx. well i plan on goin performance if all my questions are solved by a friend. i think im gonna go for:
exhaust--> rims--> suspension--> clutch--> h22a--> ?
Please dont do it that way.. although it might seem cool to have a loud exhaust now, its not gonna really help ur performance and it will make you look like a ricer. You should get ur suspension done now, then rims and tires, and then ur engine. Don't buy a clutch for ur d-series tranny if you are gonna swap to an h22. Once you have ur engine, then get the bolt ons.
suspension--> wheels/tires--> H22A--> I/H/E--> ...and so on.
Re: 1st mod (joe_bocc)
You shouldn't get an exhaust first because the h22 cat may and probably does line up different. Also, you will need different exhausts than the stock d16 because of the exhaust velocity differences. I'd probably go
Needs a little revision...
Re: 1st mod (all stock)
i'm with everyone on the suspension.... even though i did it backwards. i felt that when i had the money for my motor i would buy that first, just because that is a BIG buy if you ask me. then you get the suspension done the way you need it (since your going H22). then the bolt ons, brakes (since youll be haulin ****), then looks
Re: 1st mod (HybridHackBatch)
whats a good set-up for suspension?
Im thinkin of 16s on the wheels
if a h22a is in the civic i woudl just need to buy exhaust for dx right? will i have to modify it to fit or anything?
suspension--> wheels--> brakes--> h22a
[Modified by nocaryet, 2:45 AM 3/30/2003]
Re: 1st mod (SOHC NoTEC)
Whats the use of getting HONDATA if you have nothing to tune with it...
Damn newbies...
Damn newbies...
hondata is a good investment tunet or not !... i wish a had one for my car..
cause you can still control everything with it and then some and get the car 2 perform perfeckt..
I really don't know
do you want to drag race? autocross? road race? Drive fast on and off on and off ramps?
When you answer this you will be able to get better opinions.
