Project D16Z6 N/A
Solbros Owns Me
Project D16Z6 N/A
UPDATED 4-15
Here's some progress I made. I decided to assemble the bottom end last night and this morning before school. All clearances are perfect and I'm ready to pull my engine and swap the needed parts over and make sure I have enough piston to valve clearance. It should go in in about a week, after we drop in my room mate's new engine into his Type R...
and yes, I assembled in my living room so I could stay within room temp so I could get accurate measurements...plus, I only have 1 engine stand
Well, finally got the chance to head back home and pick up my fresh block from my brother's work- Edward's Engines in Spokane, WA.
I got a spare Z6 long block from a buddy, which I sent in and had all the machine work done. I got brand new p29 pistons mated on stock Z6 rods which were shot peened and heat treated, bored/honed block, crank grind, balanced reciprocating assembly, and all new bearings/gaskets for the bottom end for a VERY god deal.
The build up will begin after I finish my room mates B18C5 build with Darton sleeve kit, Endyn pistons, Eagle rods, etc....so it will be about a week for an update(only have 1 engine stand).
Here's some pics....
p29 pistons on recon rods...nice dome huh???( sorry for the messy room...lol-you can see some of my 8x10 photos in the back...)
Kind dark, but you all know what a fresh cylinder looks like...
Here's the block in saran wrap...lol. Nice and clean.
Modified by Emerika at 12:31 PM 4/15/2003
Solbros Owns Me
Re: Project D16Z6 N/A (lazy bum shaughn)
yup....should have added...
this will be mated to my head in the car now...
port/polished
milled .020
ZEX street/strip cam
and a 3 angle valve job...
with compression numbers reading between 125 and 145 across all 4, I hit 114 whp last weekend. I figure with a stock rebuild I would gain about 10-15 wheel, but with the high comp and then Hondata s100, I'm hoping for 150-160 wheel...we'll see though
port/polished
milled .020
Solbros Owns Me
Re: Project D16Z6 N/A (eddiecut)
my engine will be done before you....but then I need to do my tranny
I'm going to hate the 3rd gear grind after I get this broken in
Re: Project D16Z6 N/A (Emerika)
Sweet dude. I keep thinking I'm going to do something with this spare D16Z6 longblock I have sitting around but I'm poor and I need to make my car run right how it is right now before I start dropping more money into fun stuff.
Good luck with the project and let us know how it turns out.
Solbros Owns Me
Re: Project D16Z6 N/A (JV)
another nice thing for the build would be a srr 4.9 for the tranny
I am looking to find a spare YS1 tranny to do ZC 3rd gear and SRR final drive in the future, but stock YS1 will have to do for now.
Fuggin sweet man...
Sorry for my ignorance, but which motor do the p29 pistons come from?
150-160whp or more could be right around the corner for you with that setup. Good luck man, nice job.
[Modified by RyanCivic2000, 12:55 AM 3/29/2003]
Re: Project D16Z6 N/A (RyanCivic2000)
did you get the pistons new or used? i was goin to get them new.....til i got the quote for em.
sick set up im gonna wait for the review.
Solbros Owns Me
Re: Project D16Z6 N/A (djhatch)
got the pistons new. They aren't Honda made, but made by an aftermarket supplier which is just as good of quality, if not better. The pistons were perfectly balanced out of the box and with rings cost me 100 bucks through my brothers work
We'll see how these hold up, but the shop's been using them for awhile and had nothing bu great results
looks very nice emerika.. please keep up updated.. and may I ask what header are you using? and have you planned to possibly use Bisi's designed header? also do you plan to run the stock intake manifold and possibly upgrade to the skunk or JG unit. good luck I know this is a budget build up and it looks promising
New User
Re: Project D16Z6 N/A (IM ALL BOB)
looks like a fun project! i may be picking a d16z6 for my rex.. but havent figured what to do to it.. boost just sounds so much more fun!
Re: Project D16Z6 N/A (zeroracerh)
Very nice. About time we see some more SOHC power out there.
hell ya thats what im talking about!
and it's pretty rare to see an all-motor SOHC build-up. most people go boost.
Former Moderator
Re: Project D16Z6 N/A (B18C5-EH2)
I'm just simply telling him that his goal of 150-160whp is possible. I don't have any charts I've seen the setup, but never built it. He could probably get more out of it with a y8 head though, for the compression. Good luck Emerika, post some dyno results if you can!
Not my engine, but i found a chart, with minimal info.
I posted this on the other thread too. It's a jg build.
http://www.jgenginedynamics.com/dynotests
Edit: Sweet stuff Emerika! Good job. D motors rule.
[Modified by Eee Pee, 11:54 AM 3/29/2003]
Re: Project D16Z6 N/A (Eee Pee)
cool project man, i always wondered what you could do N/A with a d series. let us know when you get it started and finished.
New User
Re: Project D16Z6 N/A (tek_civic)
however with the NA setup being able to pull off 160whp thats awesome! condidering a stock b16a cant put out that much power
hi emerika..I had a couple of q's:
why do you say you are going to get a 3rd gear grind after it breaks in? is that a normal thing in the d16z6 trannys?
also, has the P29 piston-in-D16 been done before? I hear it all the time with a couple of guys here on HT, but when people actually do it, is it totally streetable/reliable with the upped compression?
thanx a lot.
thanx a lot.
Quit playing with the pictures, and get to work!
Finally got my computer working home again...BTW. Now I can track your progress with your buddy Danish, Croissant, or whatever his name is.
Re: Project D16Z6 N/A (ThunderLips)
im wondering, with all the labor, and costs [if you were to pay full price],
is the d series build up worth it in the end?
it seems like a lot of hard work, to get to 115hp - 150hp imo.
what would be the costs with this set up, without the discounts/free bees you got?
would you have done it, if you had to pay for everything?
