Del sol A/C
Del sol A/C
ok i have a 93 with ac and a 95 with out can i just put every thing from the 93 in the 95 and have it charged and it will work or is the some kind of harness i will need to biuld for this?
Re: Del sol A/C (Solster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solster »</TD></TR><TR><TD CLASS="quote">ok i have a 93 with ac and a 95 with out can i just put every thing from the 93 in the 95 and have it charged and it will work or is the some kind of harness i will need to biuld for this?</TD></TR></TABLE>
no, well yes, but no.
you see, first you will have to get the freon removed and that consists of you going to a a/c shop or mechanic and having them remove it.
second, honda's prior to 1994 used r12 freon for the a/c system. which is "more harmful" for the enviroment. so if you want to put a/c in the the 95 del sol, try to get a system off of a 94 and up del sol.
Re: Del sol A/C (philosofy1)
the 93 had the retro kit done befor i got it . Big Sticker on core support reading R134a retro fit 7.23.1998 by Ron tonkin honda of portland.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solster »</TD></TR><TR><TD CLASS="quote">the 93 had the retro kit done befor i got it . Big Sticker on core support reading R134a retro fit 7.23.1998 by Ron tonkin honda of portland.</TD></TR></TABLE>
well, if that is the case, then go ahead and swap it out.
Go_Race_Your_Self
28
02-14-2020 06:52 PM
gSx.
01-08-2004 12:04 AM
