Water Pump gasket
Water Pump gasket
i have a 94 civic with the stock d15b7, auto
it's up for a timing belt change and i'm going to buy the everything online at "hondaautomotiveparts". While looking at the diagrams it seems to me that the water pump doesn't come with the gasket and i have to spend extra to get the gasket( it says it's an o-ring and not gasket too, but picture has it as gasket)
i'm pretty lost now.. does it include the water pump gasket or no?
the part number for the water pump is 19200-p01-004, anyone has experience with the honda water pumps?
side ques: the water pump has already started to leak intermittently, how much longer will my belt and pump last?
Re: Water Pump gasket (hondmywrld)
If its already leaking and your doing the work change it out. You can also get the gasket cheap at a local autoparts store. If you go to Honda, I think you have to buy the gasket seperate. If you can afford it replace the tensioner too.
arielb1
07-17-2007 09:13 AM
CrazyKoreanCrx
08-23-2004 01:55 PM
