NEED HELP WITH AUDIO?!!?!?!?
well my eg harness has been cut and and everytime i connect the yellow wire to the white/blue wire it wont work but when i connect the red and yellow wire to the power of the car harness it works fine but theres no memory. is there any alternative wire i can connect too?
Re: NEED HELP WITH AUDIO?!!?!?!? (646EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 646EG »</TD></TR><TR><TD CLASS="quote">well my eg harness has been cut and and everytime i connect the yellow wire to the white/blue wire it wont work but when i connect the red and yellow wire to the power of the car harness it works fine but theres no memory. is there any alternative wire i can connect too?</TD></TR></TABLE>
Sounds to me that you are not wiring the 12v constant correctly thats why youare getting no memory. I would post up in the audio and security forum to get more help though. Are you sure you have the correct wiring diagram? stock radio or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 646EG »</TD></TR><TR><TD CLASS="quote">nope i bought a new cd player
i did this before
but for some reason theres no power</TD></TR></TABLE>
If its a different deck the wiring might be different. Do you have the correct wiring diagram for your car and the wiring diagram for the deck? those will be your key to getting it to work, just match up the appropriate wire color from the car to the right one on the head unit
i did this before
there two powers!!!!
constants power 12v
and acc which is key on power.
if you did this before you would know that.
hello!
constants power 12v
hello!
odogg726
Audio / Security / Video
05-28-2007 10:13 PM
nocturnal EG
16
11-03-2006 08:04 AM
