Graddy EVO exhaust on EK coupe???
Greddy EVO exhaust on EK coupe???
Can someone who has one tell me if the Greddy EVO catback for a 96-00 coupe runs in the factory location of the stock exhaust? Any help would be appreciated. Thanks in advance.
Dustin
By the way I just noticed I messed up on the title but I meant Greddy. Blah blah whatever.
Dustin
Re: Greddy EVO exhaust on EK coupe??? (EFRue57)
well one would assume that if you buy a GReddy catback exhaust for your specific model, then it should fit in all the stock locations.
Re: Greddy EVO exhaust on EK coupe??? (crx_si-r)
^What he said. If its for your Ej8 Coupe, I'm assuming, then you should be fine. Most exhausts from EK's and Ej8's are interchangeable, as long as you do them right.
Re: Greddy EVO exhaust on EK coupe??? (SpoonFedEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r »</TD></TR><TR><TD CLASS="quote">well one would assume that if you buy a GReddy catback exhaust for your specific model, then it should fit in all the stock locations.</TD></TR></TABLE>
no sir because right now I have an HKS catback designed for my coupe and it does not follow the factory location. the piping goes under the lower control arm instead of over it. so back to my original question that if someone who has one could please reply i would appreciate it.
Modified by EFRue57 at 8:12 PM 7/15/2008
Re: (98TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TT »</TD></TR><TR><TD CLASS="quote">it should work no problem as long as it is designed for your application</TD></TR></TABLE>
Okay, I understand very well that it is going to fit and bolt up with no problems. That's not what I'm asking. What I want to know basically is does the piping go under the rear lower control arm or over the rear lower control arm like the factory exhaust? Maybe I should have been more specific from the start.
I have a greddy evo 2 and it runs the exact stock path and fits extremely well on a 1999 civic coupe. just dont forget.. if your car has the cat in the stock header its different. for example.. a civic dx has the cat in the header but the ex does not.. so the mid pipe lenght is differnt. the dx greddy evo 2 for a dx however.. does fit an ex if you remove the cat.
Re: Greddy EVO exhaust on EK coupe??? (biggjerryc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggjerryc »</TD></TR><TR><TD CLASS="quote">I have a greddy evo 2 and it runs the exact stock path and fits extremely well on a 1999 civic coupe. just dont forget.. if your car has the cat in the stock header its different. for example.. a civic dx has the cat in the header but the ex does not.. so the mid pipe lenght is differnt. the dx greddy evo 2 for a dx however.. does fit an ex if you remove the cat.</TD></TR></TABLE>
thank you very much. that's what i needed to know.
White95SiHB
10-27-2005 05:39 AM
