i have a wieard problem
i jst put a motor into my eg6 and for some reason wen i went to start it it wouldnt start.so i notiiced dat there was a bad smell of gas around the car and my frieand told me dat the motor is sounds like its flooded wit gas.so wat i did was i turned the key to the position wen the fuel pump turns on and then took out the key and i disconnted the fuel pump .and then i tried to start the car wit the fuel pump disconnected and it started right up then i pluged the fuel pump wire right back up and the motor sounded like it was choking on gas please help anybody i would appreciate it.
New User
Try switching out injectors. A lot of the honda motors used the same style injector so you should be able to use the ones from your old motor at least for testing purposes. Also see if you can narrow down which cylinder is being affected.
Mr. Badwrench
Re: (illassek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illassek9 »</TD></TR><TR><TD CLASS="quote">well i dnt think so but i do have check engine lights for map and tps</TD></TR></TABLE>
start there.
thats is a common mix up on swaps.
start there.
lsvtec95
24
06-03-2007 12:03 AM
